在完成 AutoLISP 表达式计算时触发。 支持的平台:仅窗口 言论此事件将在 AutoLISP 评估正常终止或取消 AutoLISP 评估后发生。 显示模式对话框时不会触发任何事件。 例子工 务 局: Private Sub AcadDocument_EndLisp() ' This example intercepts a drawing BeginLisp event. ' ' This event is triggered when a drawing finishes ' a the evaluation of a LISP expression. ' ' To trigger this example event: Start the evaluation of a LISP expression and ' wait for it to finish being evaluated MsgBox "A LISP expression has just finished being evaluated!" End Sub Visual LISP: Not available |
GMT+8, 2024-6-10 23:46
