在停用绘图窗口时触发。 支持的平台:仅窗口 言论显示模式对话框时不会触发任何事件。 例子工 务 局: Private Sub AcadDocument_Deactivate() ' This example intercepts a drawing DeActivate event. ' ' This event is triggered when a drawing window loses focus. ' ' To trigger this example event: Open two drawings and switch from ' one drawing window to another MsgBox "You have just deactivated a drawing!" End Sub Visual LISP: Not available |
( 苏ICP备2022047690号-1 )
GMT+8, 2024-6-11 05:21
