在 AutoCAD 收到打印图形的请求后立即触发。 支持的平台:仅窗口 签名工 务 局: object.BeginPlot(DrawingName) 言论显示模式对话框时不会触发任何事件。 例子工 务 局: Private Sub AcadDocument_BeginPlot(ByVal DrawingName As String) ' This example intercepts a drawing BeginPlot event. ' ' This event is triggered when a drawing receives a plot request. ' ' To trigger this example event: Plot an open drawing ' Use the "DrawingName" variable to determine which drawing is about to plot MsgBox "A drawing has just received a request to plot for: " & DrawingName End Sub Visual LISP: Not available |
GMT+8, 2024-6-10 17:06
