在用户双击图形中的对象后触发。 支持的平台:仅窗口 签名工 务 局: object.BeginDoubleClick(PickPoint)
言论显示模式对话框时不会触发任何事件。 例子工 务 局: Private Sub AcadDocument_BeginDoubleClick(ByVal PickPoint As Variant) ' This example intercepts a drawing BeginDoubleClick event. ' ' This event is triggered when a drawing receives ' a double mouse click in its working area. ' ' To trigger this example event: Position the mouse over the working area of ' a drawing window and double-click the left mouse button ' Use the "PickPoint" variable to determine where on the drawing the user clicked MsgBox "A drawing has just been double-clicked at:" & vbCrLf & _ PickPoint(0) & vbCrLf & _ PickPoint(1) & vbCrLf & _ PickPoint(2) End Sub Visual LISP: Not available |
GMT+8, 2024-6-2 21:58
