激活文档窗口时触发。 支持的平台:仅窗口 言论显示模式对话框时不会触发任何事件。 例子工 务 局: Private Sub AcadDocument_Activate() ' This example intercepts a drawing Activate event. ' ' This event is triggered when a drawing window becomes active. ' ' To trigger this example event: Either open a new drawing or switch from ' one drawing window to another MsgBox "You have just activated a drawing!" End Sub Visual LISP: Not available |
GMT+8, 2024-6-10 22:20
