确定与外部参照相关的图层的可见性,并指定是否保存嵌套的外部参照路径更改。 支持的平台:仅窗口 属性值只读:不 类型:布尔
言论此属性的初始值为。True 设置为 时,图层设置将与当前图形的图层表一起保存,并在会话之间保留。嵌套的外部参照路径更改将与当前图形一起保存,并在会话之间保留。True 当此属性设置为 时,对当前图形中与外部参照相关的图层所做的更改仅在当前进程中有效,但不会随图形一起保存。重新打开当前图形时,将从参考图形重新加载图层表,并且当前图形将反映这些设置。受影响的图层设置包括:开/关、冻结/解冻、颜色和线型。此设置还指定对嵌套外部参照路径所做的更改仅适用于当前进程,不与图形一起保存。False 注意:此属性的值存储在 VISRETAIN 系统变量中。
例子工 务 局: Sub Example_XRefLayerVisibility() ' This example reads and modifies the preference value that controls ' the visibility of xref-dependent layers and specifies if nested xref ' path changes are saved. ' ' When finished, this example resets the preference value back to ' its original value. Dim ACADPref As AcadDatabasePreferences Dim originalValue As Variant, newValue As Variant ' Get the user preferences object Set ACADPref = ThisDrawing.preferences ' Read and display the original value originalValue = ACADPref.XRefLayerVisibility MsgBox "The XRefLayerVisibility preference is set to: " & originalValue ' Modify the XRefLayerVisibility preference by toggling the value ACADPref.XRefLayerVisibility = Not (ACADPref.XRefLayerVisibility) newValue = ACADPref.XRefLayerVisibility MsgBox "The XRefLayerVisibility preference has been set to: " & newValue ' Reset the preference back to its original value ' ' * Note: Comment out this last section to leave the change to ' this preference in effect ACADPref.XRefLayerVisibility = originalValue MsgBox "The XRefLayerVisibility preference was reset back to: " & originalValue End Sub Visual LISP: (vl-load-com) (defun c:Example_XRefLayerVisibility() ;; This example reads and modifies the preference value that controls ;; the visibility of xref-dependent layers and specifies if nested xref ;; path changes are saved. ;; ;; When finished, this example resets the preference value back to ;; its original value. (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) (setq preferences (vla-get-Preferences doc)) ;; Read and display the original value (setq originalValue (vla-get-XRefLayerVisibility preferences)) (alert (strcat "The XRefLayerVisibility preference is set to: " (if (= originalValue :vlax-true) "True" "False"))) ;; Modify the XRefLayerVisibility preference by toggling the value (vla-put-XRefLayerVisibility preferences (if (= originalValue :vlax-true) :vlax-false :vlax-true)) (alert (strcat "The XRefLayerVisibility preference has been set to: " (if (= (vla-get-XRefLayerVisibility preferences) :vlax-true) "True" "False"))) ;; Reset the preference back to its original value ;; ;; * Note: Comment out this last section to leave the change to ;; this preference in effect (vla-put-XRefLayerVisibility preferences originalValue) (alert (strcat "The XRefLayerVisibility preference was reset back to: " (if (= originalValue :vlax-true) "True" "False"))) ) |
GMT+8, 2024-6-11 03:31
