控制外部参照的调光强度。 支持的平台:仅窗口 属性值只读:不 类型:长 一个介于 1 到 90 之间的正长整数,表示 XRef 的淡入淡出百分比。 言论此属性的初始值为 50。 注意:此属性的值存储在 XFADECTL 系统变量中。
例子工 务 局: Sub Example_XRefFadeIntensity() ' This example reads and modifies the preference value that controls ' the dimming intensity for xrefs. When finished, this example resets ' the preference value back to its original value. ' ' * Note: Changes can only be observed when in-place editing of an Xref ' object is in progress and other entities are visible. Dim ACADPref As AcadPreferencesDisplay Dim originalValue As Variant, newValue As Variant ' Get the display preferences object Set ACADPref = ThisDrawing.Application.preferences.DISPLAY ' Read and display the original value originalValue = ACADPref.XRefFadeIntensity MsgBox "The XRefFadeIntensity preference is: " & originalValue ' Modify the XRefFadeIntensity preference by setting it to 75 ACADPref.XRefFadeIntensity = 75 newValue = ACADPref.XRefFadeIntensity ThisDrawing.Regen acAllViewports MsgBox "The XRefFadeIntensity preference has been set to: " & newValue ' Reset the preference back to its original value ' ' * Note: Comment out this last section to leave the change to ' this preference in effect ACADPref.XRefFadeIntensity = originalValue ThisDrawing.Regen acAllViewports MsgBox "The XRefFadeIntensity preference was reset back to: " & originalValue End Sub Visual LISP: (vl-load-com) (defun c:Example_XRefFadeIntensity() ;; This example reads and modifies the preference value that controls ;; the dimming intensity for xrefs. When finished, this example resets ;; the preference value back to its original value. ;; ;; * Note: Changes can only be observed when in-place editing of an Xref ;; object is in progress and other entities are visible. (setq acadObj (vlax-get-acad-object)) (setq preferences (vla-get-Preferences acadObj)) ;; Read and display the original value (setq originalValue (vla-get-XRefFadeIntensity (vla-get-Display preferences))) (alert (strcat "The XRefFadeIntensity preference is: " (itoa originalValue))) ;; Modify the XRefFadeIntensity preference by setting it to 75 (vla-put-XRefFadeIntensity (vla-get-Display preferences) 75) (vla-Regen doc acAllViewports) (alert (strcat "The XRefFadeIntensity preference has been set to: " (itoa (vla-get-XRefFadeIntensity (vla-get-Display preferences))))) ;; Reset the preference back to its original value ;; ;; * Note: Comment out this last section to leave the change to ;; this preference in effect (vla-put-XRefFadeIntensity (vla-get-Display preferences) originalValue) (vla-Regen doc acAllViewports) (alert (strcat "The XRefFadeIntensity preference was reset back to: " (itoa (vla-get-XRefFadeIntensity (vla-get-Display preferences))))) ) |
GMT+8, 2024-6-2 17:22
