获取样条的权重向量。 支持的平台:仅窗口 属性值只读:不 类型:变体(双精度的三元素数组) 样条的权重矢量。 言论没有额外的评论。 例子工 务 局: Sub Example_Weights() ' This example creates a Spline object in model space and ' returns the weight vector for the new Spline Dim splineObj As AcadSpline Dim startTan(0 To 2) As Double, endTan(0 To 2) As Double Dim fitPoints(0 To 8) As Double Dim weightVector As Variant ' Define the Spline object startTan(0) = 0.5: startTan(1) = 0.5: startTan(2) = 0 endTan(0) = 0.5: endTan(1) = 0.5: endTan(2) = 0 fitPoints(0) = 0: fitPoints(1) = 0: fitPoints(2) = 0 fitPoints(3) = 5: fitPoints(4) = 5: fitPoints(5) = 0 fitPoints(6) = 10: fitPoints(7) = 0: fitPoints(8) = 0 ' Create new Spline object Set splineObj = ThisDrawing.ModelSpace.AddSpline(fitPoints, startTan, endTan) ' Add weights to the Spline splineObj.SetWeight 0, 1.5 splineObj.SetWeight 1, 2 splineObj.SetWeight 2, 4.5 ThisDrawing.Application.ZoomAll ' Display the weight vector of the new Spline weightVector = splineObj.Weights MsgBox "The weight vector of the new Spline is: " & vbCrLf & _ weightVector(0) & vbCrLf & _ weightVector(1) & vbCrLf & _ weightVector(2) End Sub Visual LISP: (vl-load-com) (defun c:Example_Weights() ;; This example creates a Spline object in model space and ;; returns the weight vector for the new Spline (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) ;; Define the Spline object (setq startTan (vlax-3d-point 0.5 0.5 0) endTan (vlax-3d-point 0.5 0.5 0) fitPoints (vlax-make-safearray vlax-vbDouble '(0 . 8))) (vlax-safearray-fill fitPoints '(0 0 0 5 5 0 10 0 0 ) ) ;; Create new Spline object (setq modelSpace (vla-get-ModelSpace doc)) (setq splineObj (vla-AddSpline modelSpace fitPoints startTan endTan)) (vla-ZoomAll acadObj) ;; Add weights to the Spline (vla-SetWeight splineObj 0 1.5) (vla-SetWeight splineObj 1 2) (vla-SetWeight splineObj 2 4.5) (vla-ZoomAll acadObj) ;; Display the weight vector of the new Spline (setq weightVector (vlax-variant-value (vla-get-Weights splineObj))) (alert (strcat "The weight vector of the new Spline is: " "\n" (rtos (vlax-safearray-get-element weightVector 0) 2) "\n" (rtos (vlax-safearray-get-element weightVector 1) 2) "\n" (rtos (vlax-safearray-get-element weightVector 2) 2))) ) |
GMT+8, 2024-6-11 00:27
