指定要打印的视图的名称。 支持的平台:仅窗口 属性值只读:不 类型:字符串 要打印的视图的名称。 言论要将打印指定到视图,请将布局或打印配置的属性设置为。PlotTypeacView 例子工 务 局: Sub Example_ViewToPlot() ' This example reads a list of available Named Views and displays a plot preview ' of the view selected by the user. The current view to plot, ' if set, if preceded by an '*' ' ' * Note: After previewing the plot, you will have to exit the ' plot preview before the VBA example will stop and control will be returned Dim ViewList As New Collection Dim View As AcadView Dim iCount As Long Dim msg As String Dim ViewName As String, ViewNum As String ' Get list of views available to plot For Each View In ThisDrawing.Views ViewList.Add View Next ' Are there any named views to plot If ViewList.count = 0 Then MsgBox "There are no named views to plot.", vbInformation Exit Sub End If ' Read and display the current plot style table path For iCount = 1 To ViewList.count ViewName = ViewList(iCount).Name If ViewName = ThisDrawing.ActiveLayout.ViewToPlot Then ' Is this the current view to plot ViewNum = iCount ViewName = "*" & ViewName End If msg = msg & "(" & iCount & ") " & vbTab & ViewName & vbCrLf Next ' Prompt user for the view to plot RETRY: ViewNum = InputBox("Which view would you like to plot?" & vbCrLf & vbCrLf & msg, "View To Plot", ViewNum) If Trim(ViewNum) = "" Then Exit Sub End If If Not (IsNumeric(ViewNum)) Then MsgBox "You must supply a numeric value corresponding to one of the views listed above.", vbExclamation GoTo RETRY End If ' Tell the drawing which view to plot ThisDrawing.ActiveLayout.ViewToPlot = ViewList(CLng(ViewNum)).Name ' Make sure you tell the drawing to plot a view, not some other plot style ThisDrawing.ActiveLayout.PlotType = acView ' Send Plot To Window ThisDrawing.ActiveLayout.ConfigName = "DWG to PDF.pc3" ThisDrawing.Plot.DisplayPlotPreview acFullPreview End Sub Visual LISP: (vl-load-com) (defun c:Example_ViewToPlot() ;; This example reads a list of available Named Views and displays a plot preview ;; of the view selected by the user. The current view to plot, ;; if set, if preceded by an '*' ;; ;; * Note: After previewing the plot, you will have to exit the ;; plot preview before the VBA example will stop and control will be returned (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) ;; Get list of views available to plot (setq viewList (vlax-make-safearray vlax-vbObject (cons 0 (vla-get-Count (vla-get-Views doc)))) cnt 0) (vlax-for view (vla-get-Views doc) (vlax-safearray-put-element viewList cnt view) (setq cnt (1+ cnt)) ) ;; Are there any named views to plot (if (> (vla-get-Count (vla-get-Views doc)) 0) (progn ;; Read and display the current plot style table path (setq iCount 0 msg "") (while (> (vla-get-Count (vla-get-Views doc)) iCount) (setq viewName (vla-get-Name (vlax-safearray-get-element ViewList iCount))) (if (= viewName (vla-get-ViewToPlot (vla-get-ActiveLayout doc))) ;; Is this the current view to plot (setq ViewNum (1+ iCount) ViewName (strcat "*" ViewName)) ) (setq iCount (1+ iCount) msg (strcat msg "(" (itoa iCount) ") " viewName "\n")) ) ;; Prompt user for the view to plot (setq viewNum (vla-GetInteger (vla-get-Utility doc) (strcat "\nWhich view would you like to plot?\n" msg))) (if (and (<= viewNum (vla-get-Count (vla-get-Views doc))) (> viewNum 0)) (progn ;; Tell the drawing which view to plot (vla-put-ViewToPlot (vla-get-ActiveLayout doc) (vla-get-Name (vlax-safearray-get-element ViewList (1- viewNum)))) ;; Make sure you tell the drawing to plot a view, not some other plot style (vla-put-PlotType (vla-get-ActiveLayout doc) acView) (vla-put-ConfigName (vla-get-ActiveLayout doc) "DWF6 ePlot.pc3") ;; Send Plot To Window (vla-DisplayPlotPreview (vla-get-Plot doc) acFullPreview) ) (alert "The view number entered is not valid.") ) ) (alert "There are no named views to plot.") ) ) |
GMT+8, 2024-6-11 01:31
