获取文档的视图集合。 支持的平台:仅窗口 言论没有额外的评论。 例子工 务 局: Sub Example_Views() ' This example finds the current views collection and ' adds a new view to that collection. Dim viewColl As AcadViews Set viewColl = ThisDrawing.Views ' Create a view named "TEST" in the current drawing Dim viewObj As AcadView Set viewObj = viewColl.Add("TEST") MsgBox "A new view called " & viewObj.name & " has been added to the views collection.", vbInformation, "Views Example" End Sub Visual LISP: (vl-load-com) (defun c:Example_Views() ;; This example finds the current views collection and ;; adds a new view to that collection. (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) (setq viewColl (vla-get-Views doc)) ;; Create a view named "TEST" in the current drawing (setq viewObj (vla-Add viewColl "TEST")) (alert (strcat "A new view called " (vla-get-Name viewObj) " has been added to the views collection.")) ) |
GMT+8, 2024-6-11 04:00
