获取文档的视口集合。 支持的平台:仅窗口 言论没有额外的评论。 例子工 务 局: Sub Example_Viewports() ' This example finds the current Viewports collection and ' adds a new viewport to that collection. Dim viewportColl As AcadViewports Set viewportColl = ThisDrawing.Viewports ' Create a viewport named "TEST" in the current drawing Dim viewportObj As AcadViewport Set viewportObj = viewportColl.Add("TEST") MsgBox "A new viewport called " & viewportObj.name & " has been added to the Viewports collection.", vbInformation, "Viewports Example" End Sub Visual LISP: (vl-load-com) (defun c:Example_Viewports() ;; This example finds the current Viewports collection and ;; adds a new viewport to that collection. (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) (setq viewportColl (vla-get-Viewports doc)) ;; Create a viewport named "TEST" in the current drawing (setq viewportObj (vla-Add viewportColl "TEST")) (alert (strcat "A new viewport called " (vla-get-Name viewportObj) " has been added to the Viewports collection.")) ) |
GMT+8, 2024-6-10 21:51
