指定是否在新视口中冻结图层。 支持的平台:仅窗口 属性值只读:不 类型:布尔
言论没有额外的评论。 例子工 务 局: Sub Example_ViewportDefault() ' This example creates a new layer called "New_Layer". It then uses ' the ViewportDefault property of each Layer to display whether or not that layer ' is frozen in new viewports. The user has the ability to toggle whether or not ' each layer will be frozen in new viewports, and the final ViewportDefault status ' for all layers is displayed. Dim layerObj As AcadLayer, tempLayer As AcadLayer Dim msg As String ' Add the layer to the layers collection Set layerObj = ThisDrawing.Layers.Add("New_Layer") ' Make the new layer the active layer for the drawing ThisDrawing.ActiveLayer = layerObj ' Cycle through the layers and allow user to make them frozen in new viewports or not For Each tempLayer In ThisDrawing.Layers If tempLayer.ViewportDefault Then ' Determine if this layer is fozen in new viewports If MsgBox("The layer '" & tempLayer.name & "' will be frozen in new viewports. Would you like to make this layer unfrozen in new viewports?", vbYesNo & vbQuestion) = vbYes Then tempLayer.ViewportDefault = False ' Change frozen state End If Else If MsgBox("The layer '" & tempLayer.name & "' will not be frozen in new viewports. Would you like to make this layer frozen in new viewports?", vbYesNo & vbQuestion) = vbYes Then tempLayer.ViewportDefault = True ' Change frozen state End If End If Next ' Display the new viewport freeze status of the layers in this drawing For Each tempLayer In ThisDrawing.Layers ' Determine if this layer is frozen in new viewports If tempLayer.ViewportDefault Then msg = msg & "The layer '" & tempLayer.name & "' will be frozen in new viewports." & vbCrLf Else msg = msg & "The layer '" & tempLayer.name & "' will not be frozen in new viewports." & vbCrLf End If Next MsgBox msg End Sub Visual LISP: (vl-load-com) (defun c:Example_ViewportDefault() ;; This example creates a new layer called "New_Layer". It then uses ;; the ViewportDefault property of each Layer to display whether or not that layer ;; is frozen in new viewports. The user has the ability to toggle whether or not ;; each layer will be frozen in new viewports, and the final ViewportDefault status ;; for all layers is displayed. ;; Add the layer to the layers collection (setq layerObj (vla-Add (vla-get-Layers doc) "New_Layer")) ;; Make the new layer the active layer for the drawing (vla-put-ActiveLayer doc layerObj) ;; Cycle through the layers and allow user to make them frozen in new viewports or not (vlax-for tempLayer (vla-get-Layers doc) ;; Display the current new viewports layer state (if (= (vla-get-ViewportDefault tempLayer) :vlax-true) (alert (strcat "The layer '" (vla-get-Name tempLayer) "' is frozen for new viewports. Toggling state now.")) (alert (strcat "The layer '" (vla-get-Name tempLayer) "' is not frozen for new viewports. Toggling state now.")) ) (vla-put-ViewportDefault tempLayer (if (= (vla-get-ViewportDefault tempLayer) :vlax-true) :vlax-false :vlax-true)) ) ;; Display the new viewport freeze status of the layers in this drawing (setq msg "") (vlax-for tempLayer (vla-get-Layers doc) ;; Determine if this layer is frozen in new viewports (if (= (vla-get-ViewportDefault tempLayer) :vlax-true) (setq msg (strcat msg "The layer '" (vla-get-Name tempLayer) "' will be frozen in new viewports.\n")) (setq msg (strcat msg "The layer '" (vla-get-Name tempLayer) "' will not be frozen in new viewports.\n")) ) ) (alert msg) ) |
GMT+8, 2024-6-10 20:23
