指定绘图是使用标准比例还是自定义比例。 支持的平台:仅窗口 属性值只读:不 类型:布尔
言论要指定要在绘图中使用的标准比例,请使用属性。若要指定自定义比例,请使用方法。StandardScaleSetCustomScale 例子工 务 局: Sub Example_UseStandardScale() ' This example will access the Layouts collection for the current drawing ' and list the status of UseStandardScale for each Layout. Dim Layouts As AcadLayouts, Layout As ACADLayout Dim msg As String ' Get layouts collection from document object Set Layouts = ThisDrawing.Layouts msg = "" ' Get the UseStandardScale information of every layout in this drawing For Each Layout In Layouts If Layout.UseStandardScale Then msg = msg & Layout.name & " uses the standard scale." & vbCrLf Else msg = msg & Layout.name & " uses a custom scale." & vbCrLf End If Next ' Display the information MsgBox msg End Sub Visual LISP: (vl-load-com) (defun c:Example_UseStandardScale() ;; This example will access the Layouts collection for the current drawing ;; and list the status of UseStandardScale for each Layout. (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) ;; Get layouts collection from document object (setq Layouts (vla-get-Layouts doc) msg "") ;; Get the UseStandardScale information of every layout in this drawing (vlax-for Layout Layouts (if (= (vla-get-UseStandardScale Layout) :vlax-true) (setq msg (strcat msg (vla-get-Name Layout) " uses the standard scale.\n")) (setq msg (strcat msg (vla-get-Name Layout) " uses a custom scale.\n")) ) ) ;; Display the information (alert msg) ) |
GMT+8, 2024-6-11 04:28
