获取首选项用户对象。 支持的平台:仅窗口 签名工 务 局: object.User
言论该对象保存存储在注册表中的“选项”对话框中“用户”选项卡中的所有选项。与图形一起存储的所有选项都可以在对象上找到。PreferencesUserDatabasePreferences 例子工 务 局: Sub Example_User() ' This example obtains a reference to the User Preferences object ' from the Application Preferences object, and reads one of the User ' preferences Dim ACADPref As AcadPreferencesUser ' Obtain a reference to the User Preferences object Set ACADPref = ThisDrawing.Application.preferences.User MsgBox "You now have access to the properties and methods of the User Preferences object!" MsgBox "The User preference KeyboardAccelerator is set to: " & ACADPref.KeyboardAccelerator End Sub Visual LISP: (vl-load-com) (defun c:Example_User() ;; This example obtains a reference to the User Preferences object ;; from the Application Preferences object, and reads one of the User ;; preferences (setq acadObj (vlax-get-acad-object)) (setq preferences (vla-get-Preferences acadObj)) (alert "You now have access to the properties and methods of the User Preferences object!") (alert (strcat "The User preference KeyboardAccelerator is set to: " (if (= (vla-get-KeyboardAccelerator (vla-get-User preferences)) :vlax-true) "True" "False"))) ) |
GMT+8, 2024-6-11 05:51
