指定文本的方向。 支持的平台:仅窗口 属性值只读:不 类型:布尔
言论没有额外的评论。 例子工 务 局: Sub Example_UpsideDown() ' This example creates a text object in model space and ' uses the UpsideDown property to flip the text vertically Dim textObj As AcadText Dim textString As String Dim insertionPoint(0 To 2) As Double Dim height As Double ' Define the new Text object textString = "Hello, World." insertionPoint(0) = 3: insertionPoint(1) = 3: insertionPoint(2) = 0 height = 0.5 ' Create the Text object in model space Set textObj = ThisDrawing.ModelSpace.AddText(textString, insertionPoint, height) ThisDrawing.Application.ZoomAll MsgBox "The Text oject is now right side up" textObj.UpsideDown = True ThisDrawing.Regen acActiveViewport MsgBox "The Text object is now upside down" End Sub Visual LISP: (vl-load-com) (defun c:Example_UpsideDown() ;; This example creates a text object in model space and ;; uses the UpsideDown property to flip the text vertically (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) ;; Define the new Text object (setq insertionPoint (vlax-3d-point 3 3 0) textString "Hello, World." height 0.5) ;; Create the Text object in model space (setq modelSpace (vla-get-ModelSpace doc)) (setq textObj (vla-AddText modelSpace textString insertionPoint height)) (vla-ZoomAll acadObj) (alert "The Text oject is now right side up") (vla-put-UpsideDown textObj :vlax-true) (vla-Regen doc acActiveViewport) (alert "The Text object is now upside down") ) |
GMT+8, 2024-6-10 19:01
