设置工具选项板路径。 支持的平台:仅窗口 属性值只读:不 类型:字符串 工具选项板路径。 言论没有额外的评论。 例子工 务 局: Sub Example_ToolPalettePath() 'This example changes the tool palette path 'and then sets it to its original string Dim pref As AutoCAD.AcadPreferencesFiles Set pref = AcadApplication.Preferences.Files Dim defToolPalettePath As String Dim changedToolPalettePath As String defToolPalettePath = pref.ToolPalettePath MsgBox "The current tool palette path is " & defToolPalettePath pref.ToolPalettePath = "c:\winnt;c:\temp" changedToolPalettePath = pref.ToolPalettePath MsgBox "The changed tool palette path is " & changedToolPalettePath pref.ToolPalettePath = defToolPalettePath End Sub Visual LISP: (vl-load-com) (defun c:Example_ToolPalettePath() ;; This example changes the tool palette path ;; and then sets it to its original string (setq acadObj (vlax-get-acad-object)) (setq pref (vla-get-Files (vla-get-Preferences acadObj))) (setq defToolPalettePath (vla-get-ToolPalettePath pref)) (alert (strcat "The current tool palette path is " defToolPalettePath)) (vla-put-ToolPalettePath pref "c:\\winnt;c:\\temp") (alert (strcat "The changed tool palette path is " (vla-get-ToolPalettePath pref))) (vla-put-ToolPalettePath pref defToolPalettePath) ) |
GMT+8, 2024-6-10 23:22
