获取工具栏集合。 支持的平台:仅窗口 言论没有额外的评论。 例子工 务 局: Sub Example_Toolbars() ' This example finds the names of the all toolbars in the first menu group. Dim toolbarNames As String Dim toolbarCollection As AcadToolbars Dim toolbar As AcadToolbar Set toolbarCollection = ThisDrawing.Application.MenuGroups.Item(0).Toolbars toolbarNames = "" For Each toolbar In toolbarCollection toolbarNames = toolbarNames & toolbar.name & vbCrLf Next toolbar MsgBox toolbarNames End Sub Visual LISP: (vl-load-com) (defun c:Example_Toolbars() ;; This example finds the names of the all toolbars in the first menu group. (setq acadObj (vlax-get-acad-object)) (setq toolbarCollection (vla-get-Toolbars (vla-Item (vla-get-MenuGroups acadObj) 0)) toolbarNames "") (vlax-for toolbar toolbarCollection (setq toolbarNames (strcat toolbarNames (vla-get-Name toolbar) "\n")) ) (alert toolbarNames) ) |
GMT+8, 2024-6-2 17:19
