指定尺寸文本的最大容差限制。 支持的平台:仅窗口 属性值只读:不 类型:双 容差下限。 言论此属性的初始值为 0.0000。 仅当属性设置为 、、 或 时,此属性才可用。ToleranceDisplayacTolSymmetricalacTolDeviationacTolLimits 注意:此属性将覆盖给定维度的 DIMTP 系统变量的值。
例子工 务 局: Sub Example_ToleranceLowerLimit() ' This example creates an aligned dimension in model space and ' sets the tolerance limits using the ToleranceLowerLimit and ' ToleranceUpperLimit properties Dim dimObj As AcadDimAligned Dim newText As AcadTextStyle Dim point1(0 To 2) As Double, point2(0 To 2) As Double Dim location(0 To 2) As Double ' Define the dimension point1(0) = 5: point1(1) = 5: point1(2) = 0 point2(0) = 5.5: point2(1) = 5: point2(2) = 0 location(0) = 5: location(1) = 7: location(2) = 0 ' Create an aligned dimension object in model space Set dimObj = ThisDrawing.ModelSpace.AddDimAligned(point1, point2, location) ' Turn on tolerance display dimObj.ToleranceDisplay = acTolSymmetrical ThisDrawing.Application.ZoomAll ' Read and display the tolerance limits for the dimension MsgBox "The tolerance lower limit is set to: " & dimObj.ToleranceLowerLimit & vbCrLf & _ "The tolerance upper limit is set to: " & dimObj.ToleranceUpperLimit ' Adjust the tolerance limits for this dimension dimObj.ToleranceLowerLimit = 0.0001 dimObj.ToleranceUpperLimit = 0.005 ThisDrawing.Regen acAllViewports ' Read and display the tolerance limits for the dimension MsgBox "The tolerance lower limit is now set to: " & dimObj.ToleranceLowerLimit & vbCrLf & _ "The tolerance upper limit is now set to: " & dimObj.ToleranceUpperLimit End Sub Visual LISP: (vl-load-com) (defun c:Example_ToleranceLowerLimit() ;; This example creates an aligned dimension in model space and ;; sets the tolerance limits using the ToleranceLowerLimit and ;; ToleranceUpperLimit properties (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) ;; Define the dimension (setq point1 (vlax-3d-point 5 5 0) point2 (vlax-3d-point 5.5 5 0) location (vlax-3d-point 5 7 0)) ;; Create an aligned dimension object in model space (setq modelSpace (vla-get-ModelSpace doc)) (setq dimObj (vla-AddDimAligned modelSpace point1 point2 location)) ;; Turn on tolerance display (vla-put-ToleranceDisplay dimObj acTolSymmetrical) (vla-ZoomAll acadObj) (vla-Regen doc acAllViewports) ;; Read and display the tolerance limits for the dimension (alert (strcat "The tolerance lower limit is set to: " (rtos (vla-get-ToleranceLowerLimit dimObj) 2) "\nThe tolerance upper limit is set to: " (rtos (vla-get-ToleranceUpperLimit dimObj) 2))) ;; Adjust the tolerance limits for this dimension (vla-put-ToleranceLowerLimit dimObj 0.0001) (vla-put-ToleranceUpperLimit dimObj 0.005) (vla-Regen doc acAllViewports) ;; Read and display the tolerance limits for the dimension (alert (strcat "The tolerance lower limit is now set to: " (rtos (vla-get-ToleranceLowerLimit dimObj) 2) "\nThe tolerance upper limit is now set to: " (rtos (vla-get-ToleranceUpperLimit dimObj) 2))) ) |
GMT+8, 2024-6-10 23:33
