指定公差值的文本高度相对于尺寸文本高度的比例因子。 支持的平台:仅窗口 属性值只读:不 类型:双 容差值的比例因子。 言论此属性的初始值为 1.0000。 仅当属性设置为除以下值以外的任何值时,此属性才可用。ToleranceDisplayacTolNone 当 DIMTOL 处于打开状态且 DIMTM 不等于 DIMTP 或 DIMLIM 处于打开状态时,将此属性用于加号和减号容差字符串。 注意:此属性将覆盖给定维度的 DIMTFAC 系统变量的值。
例子工 务 局: Sub Example_ToleranceHeightScale() ' This example creates an aligned dimension in model space and ' turns on the tolerance display for the new dimension. The height ' of the tolerance text can then be adjusted by the user Dim dimObj As AcadDimAligned Dim newText As AcadTextStyle Dim point1(0 To 2) As Double, point2(0 To 2) As Double Dim location(0 To 2) As Double Dim CurrentScale As Integer ' Define the dimension point1(0) = 5: point1(1) = 5: point1(2) = 0 point2(0) = 5.5: point2(1) = 5: point2(2) = 0 location(0) = 5: location(1) = 7: location(2) = 0 ' Create an aligned dimension object in model space Set dimObj = ThisDrawing.ModelSpace.AddDimAligned(point1, point2, location) ' Turn on the tolerance display dimObj.ToleranceDisplay = acTolSymmetrical ThisDrawing.Application.ZoomAll Increase: ' Read and display the current tolerance height scale for this dimension If MsgBox("The tolerance height scale is currently set to: " & dimObj.ToleranceHeightScale & vbCrLf & _ "Press OK to increase, or cancel to finish", vbOKCancel) = vbCancel Then Exit Sub End If ' Increase the tolerance height scale for this dimension dimObj.ToleranceHeightScale = dimObj.ToleranceHeightScale + 1 ThisDrawing.Regen acAllViewports GoTo Increase End Sub Visual LISP: (vl-load-com) (defun c:Example_ToleranceHeightScale() ;; This example creates an aligned dimension in model space and ;; turns on the tolerance display for the new dimension. The height ;; of the tolerance text can then be adjusted by the user (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) ;; Define the dimension (setq point1 (vlax-3d-point 5 5 0) point2 (vlax-3d-point 5.5 5 0) location (vlax-3d-point 5 7 0)) ;; Create an aligned dimension object in model space (setq modelSpace (vla-get-ModelSpace doc)) (setq dimObj (vla-AddDimAligned modelSpace point1 point2 location)) ;; Turn on the tolerance display (vla-put-ToleranceDisplay dimObj acTolSymmetrical) (vla-ZoomAll acadObj) (vla-Regen doc acAllViewports) ;; Read and display the current tolerance height scale for this dimension (alert (strcat "The tolerance height scale is currently set to: " (rtos (vla-get-ToleranceHeightScale dimObj) 2))) ;; Increase the tolerance height scale for this dimension (vla-put-ToleranceHeightScale dimObj (1+ (vla-get-ToleranceHeightScale dimObj))) (vla-Regen doc acAllViewports) ;; Read and display the current tolerance height scale for this dimension (alert (strcat "The tolerance height scale is now set to: " (rtos (vla-get-ToleranceHeightScale dimObj) 2))) ) |
GMT+8, 2024-6-2 18:03
