指定是否将公差与尺寸文本一起显示。 支持的平台:仅窗口 属性值只读:不 类型:枚举acDimToleranceMethod
言论此属性的初始值为。acTolNone 注意:此属性覆盖给定维度的 DIMTOL 系统变量的值。
例子工 务 局: Sub Example_ToleranceDisplay() ' This example creates an aligned dimension in model space and ' turns on the tolerance display for the new dimension Dim dimObj As AcadDimAligned Dim newText As AcadTextStyle Dim point1(0 To 2) As Double, point2(0 To 2) As Double Dim location(0 To 2) As Double Dim CurrentDisplay As String ' Define the dimension point1(0) = 5: point1(1) = 5: point1(2) = 0 point2(0) = 5.5: point2(1) = 5: point2(2) = 0 location(0) = 5: location(1) = 7: location(2) = 0 ' Create an aligned dimension object in model space Set dimObj = ThisDrawing.ModelSpace.AddDimAligned(point1, point2, location) ThisDrawing.Application.ZoomAll ' Read and display the current tolerance display for this dimension CurrentDisplay = IIf(dimObj.ToleranceDisplay = acTolNone, "Hidden", "Visible") MsgBox "The tolerance display is currently: " & CurrentDisplay ' Toggle the tolerance display for this dimension If dimObj.ToleranceDisplay = acTolNone Then dimObj.ToleranceDisplay = acTolSymmetrical CurrentDisplay = "Symmetrical" Else dimObj.ToleranceDisplay = acTolNone CurrentDisplay = "None" End If ThisDrawing.Regen acAllViewports ' Display the current tolerance display for this dimension MsgBox "The tolerance display is now set to: " & CurrentDisplay End Sub Visual LISP: (vl-load-com) (defun c:Example_ToleranceDisplay() ;; This example creates an aligned dimension in model space and ;; turns on the tolerance display for the new dimension (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) ;; Define the dimension (setq point1 (vlax-3d-point 5 5 0) point2 (vlax-3d-point 5.5 5 0) location (vlax-3d-point 5 7 0)) ;; Create an aligned dimension object in model space (setq modelSpace (vla-get-ModelSpace doc)) (setq dimObj (vla-AddDimAligned modelSpace point1 point2 location)) (vla-ZoomAll acadObj) ;; Read and display the current tolerance display for this dimension (setq currentDisplay (if (= (vla-get-ToleranceDisplay dimObj) acTolNone) "Hidden" "Visible")) (alert (strcat "The tolerance display is currently: " currentDisplay)) ;; Toggle the tolerance display for this dimension (if (= (vla-get-ToleranceDisplay dimObj) acTolNone) (progn (vla-put-ToleranceDisplay dimObj acTolSymmetrical) (setq currentDisplay "Symmetrical") ) (progn (vla-put-ToleranceDisplay dimObj acTolNone) (setq currentDisplay "None") ) ) (vla-Regen doc acAllViewports) ;; Display the current tolerance display for this dimension (alert (strcat "The tolerance display is now set to: " currentDisplay)) ) |
GMT+8, 2024-6-10 16:17
