指定文本窗口的文本颜色。 支持的平台:仅窗口 属性值只读:是/否 类型:OLE_COLOR(常量)
言论此属性的默认颜色是 Windows 标准窗口文本颜色。 例子工 务 局: Sub Example_TextWinTextColor() ' This example returns the current setting of ' TextWinTextColor. It then changes the value, and finally ' it resets the value back to the original setting. Dim preferences As AcadPreferences Dim currTextWinTextColor As Long Set preferences = ThisDrawing.Application.Preferences ' Retrieve the current TextWinTextColor value currTextWinTextColor = preferences.Display.TextWinTextColor MsgBox "The current value for TextWinTextColor is " _ & preferences.Display.TextWinTextColor, vbInformation, "TextWinTextColor Example" ' Change the value for TextWinTextColor preferences.Display.TextWinTextColor = vbGreen MsgBox "The new value for TextWinTextColor is " _ & preferences.Display.TextWinTextColor, vbInformation, "TextWinTextColor Example" ' Reset TextWinTextColor to its original value preferences.Display.TextWinTextColor = currTextWinTextColor MsgBox "The TextWinTextColor value is reset to " _ & preferences.Display.TextWinTextColor, vbInformation, "TextWinTextColor Example" End Sub Visual LISP: (vl-load-com) (defun c:Example_TextWinTextColor() ;; This example returns the current setting of ;; TextWinTextColor. It then changes the value, and finally ;; it resets the value back to the original setting. (setq acadObj (vlax-get-acad-object)) (setq preferences (vla-get-Preferences acadObj)) ;; Get the Display preferences object (setq ACADPref (vla-get-Display preferences)) ;; Retrieve the current TextWinTextColor value (setq currTextWinTextColor (vlax-variant-change-type (vla-get-TextWinTextColor ACADPref) vlax-vbLong)) (alert (strcat "The current value for TextWinTextColor is " (itoa (vlax-variant-value currTextWinTextColor)))) ;; Change the value for TextWinTextColor (vla-put-TextWinTextColor ACADPref (vlax-make-variant acGreen 19)) (setq newValue (vlax-variant-change-type (vla-get-TextWinTextColor ACADPref) vlax-vbLong)) (alert (strcat "The new value for TextWinTextColor is " (itoa (vlax-variant-value newValue)))) ;; Reset TextWinTextColor to its original value (vla-put-TextWinTextColor ACADPref (vlax-variant-change-type currTextWinTextColor 19)) (alert (strcat "The TextWinTextColor value is reset to " (itoa (vlax-variant-value currTextWinTextColor)))) ) |
GMT+8, 2024-6-10 22:11
