指定维度值前缀。 支持的平台:仅窗口 属性值只读:不 类型:字符串 维度值的前缀。 言论此属性的初始值为 “”。 注意:此属性将覆盖给定维度的 DIMPOST 系统变量的值。
例子工 务 局: Sub Example_TextPrefix() ' This example creates an aligned dimension in model space and ' uses TextPrefix to allow the user to change the text prefix for the ' dimension Dim dimObj As AcadDimAligned Dim point1(0 To 2) As Double, point2(0 To 2) As Double Dim location(0 To 2) As Double Dim prefix As String ' Define the dimension point1(0) = 0: point1(1) = 5: point1(2) = 0 point2(0) = 5: point2(1) = 5: point2(2) = 0 location(0) = 5: location(1) = 7: location(2) = 0 ' Create an aligned dimension object in model space Set dimObj = ThisDrawing.ModelSpace.AddDimAligned(point1, point2, location) ThisDrawing.Application.ZoomAll ' Allow the user to change the text prefix for the dimension prefix = InputBox("Enter a new text prefix for the dimension", "Set Dimension Prefix", "PREFIX:") dimObj.TextPrefix = prefix ' Commit changes to prefix ThisDrawing.Regen acAllViewports ' Read back and display the dimension text prefix prefix = dimObj.TextPrefix If prefix <> "" Then MsgBox "The prefix of the dimension has been changed to: " & prefix Else MsgBox "The prefix of the dimension has been removed" End If End Sub Visual LISP: (vl-load-com) (defun c:Example_TextPrefix() ;; This example creates an aligned dimension in model space and ;; uses TextPrefix to allow the user to change the text prefix for the ;; dimension (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) ;; Define the dimension (setq point1 (vlax-3d-point 0 5 0) point2 (vlax-3d-point 5 5 0) location (vlax-3d-point 5 7 0)) ;; Create an aligned dimension object in model space (setq modelSpace (vla-get-ModelSpace doc)) (setq dimObj (vla-AddDimAligned modelSpace point1 point2 location)) (vla-ZoomAll acadObj) ;; Allow the user to change the text prefix for the dimension (setq prefix (vla-GetString (vla-get-Utility doc) :vlax-false "\nEnter a new text prefix for the dimension: ")) (vla-put-TextPrefix dimObj prefix) ;; Commit changes to prefix (vla-Regen doc acAllViewports) ;; Read back and display the dimension text prefix (setq prefix (vla-get-TextPrefix dimObj)) (if (/= prefix "") (alert (strcat "The prefix of the dimension has been changed to: " prefix)) (alert "The prefix of the dimension has been removed") ) ) |
GMT+8, 2024-6-2 20:09
