指定角度尺寸文本的精度。 支持的平台:仅窗口 属性值只读:不 类型:枚举acDimPrecision
言论注意:此属性覆盖给定维度的 DIMADEC 系统变量的值。
例子工 务 局: Sub Example_TextPrecision() ' This example creates a Dim3PointAngular object in model space and ' uses the TextPrecision property to set the precision of ' the dimension text to 4 decimal places Dim DimPointAngularObj As AcadDim3PointAngular Dim AngleVertex(0 To 2) As Double Dim FirstPoint(0 To 2) As Double, SecondPoint(0 To 2) As Double Dim TextPoint(0 To 2) As Double ' Define the new Dim3PointAngular object AngleVertex(0) = 0: AngleVertex(1) = 0: AngleVertex(2) = 0 FirstPoint(0) = 2: FirstPoint(1) = 2: FirstPoint(2) = 0 SecondPoint(0) = 1: SecondPoint(1) = 4: SecondPoint(2) = 0 TextPoint(0) = 6: TextPoint(1) = 6: TextPoint(2) = 0 ' Create the new Dim3PointAngular object in model space Set DimPointAngularObj = ThisDrawing.ModelSpace.AddDim3PointAngular(AngleVertex, FirstPoint, SecondPoint, TextPoint) ThisDrawing.Application.ZoomAll ' Read and display current dimension text precision MsgBox "The dimension text precision is currently set to: " & DimPointAngularObj.TextPrecision ' Increase the distance of the dimension gap DimPointAngularObj.TextPrecision = acDimPrecisionFour ThisDrawing.Regen acAllViewports ' Read and display current dimension text precision MsgBox "The dimension text precision is now set to: " & DimPointAngularObj.TextPrecision End Sub Visual LISP: (vl-load-com) (defun c:Example_TextPrecision() ;; This example creates a Dim3PointAngular object in model space and ;; uses the TextPrecision property to set the precision of ;; the dimension text to 4 decimal places (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) ;; Define the new Dim3PointAngular object (setq AngleVertex (vlax-3d-point 0 0 0) FirstPoint (vlax-3d-point 2 2 0) SecondPoint (vlax-3d-point 1 4 0) TextPoint (vlax-3d-point 6 6 0)) ;; Create the new Dim3PointAngular object in model space (setq modelSpace (vla-get-ModelSpace doc)) (setq dimPointAngularObj (vla-AddDim3PointAngular modelSpace AngleVertex FirstPoint SecondPoint TextPoint)) (vla-ZoomAll acadObj) ;; Read and display current dimension text precision (alert (strcat "The dimension text precision is currently set to: " (itoa (vla-get-TextPrecision dimPointAngularObj)))) ;; Increase the distance of the dimension gap (vla-put-TextPrecision dimPointAngularObj acDimPrecisionFour) (vla-Regen doc acAllViewports) ;; Read and display current dimension text precision (alert (strcat "The dimension text precision is now set to: " (rtos (vla-get-TextPrecision dimPointAngularObj) 2))) ) |
GMT+8, 2024-6-10 16:52
