指定新文本的字体样式。 支持的平台:仅窗口 属性值只读:不 类型:枚举acTextFontStyle
言论此属性的初始值为。acFontRegular 例子工 务 局: Sub Example_TextFontStyle() ' This example returns the current setting of ' TextFontStyle. It then changes the value, and finally ' it resets the value back to the original setting. Dim preferences As AcadPreferences Dim currTextFontStyle As Integer Dim constant As String Dim newConstant As String Set preferences = ThisDrawing.Application.Preferences ' Retrieve the current TextFontStyle value currTextFontStyle = preferences.Display.TextFontStyle constant = Choose(currTextFontStyle + 1, "acFontRegular", "acFontItalic", "acFontBold", "acFontBoldItalic") MsgBox "The current value for TextFontStyle is " & constant, vbInformation, "TextFontStyle Example" ' Change the value for TextFontStyle newConstant = "acFontBoldItalic" preferences.Display.TextFontStyle = acFontBoldItalic MsgBox "The new value for TextFontStyle is " & newConstant, vbInformation, "TextFontStyle Example" ' Reset TextFontStyle to its original value preferences.Display.TextFontStyle = currTextFontStyle MsgBox "The TextFontStyle value is reset to " & constant, vbInformation, "TextFontStyle Example" End Sub Visual LISP: (vl-load-com) (defun c:Example_TextFontStyle() ;; This example returns the current setting of ;; TextFontStyle. It then changes the value, and finally ;; it resets the value back to the original setting. (setq acadObj (vlax-get-acad-object)) (setq preferences (vla-get-Preferences acadObj)) ;; Retrieve the current TextFontStyle value (setq currTextFontStyle (vla-get-TextFontStyle (vla-get-Display preferences))) (setq constant (cond ((= currTextFontStyle acFontRegular) "acFontRegular") ((= currTextFontStyle acFontItalic) "acFontItalic") ((= currTextFontStyle acFontBold) "acFontBold") ((= currTextFontStyle acFontBoldItalic) "acFontBoldItalic") )) (alert (strcat "The current value for TextFontStyle is " constant)) ;; Change the value for TextFontStyle (vla-put-TextFontStyle (vla-get-Display preferences) acFontBoldItalic) (setq newTextFontStyle (vla-get-TextFontStyle (vla-get-Display preferences))) (setq newConstant (cond ((= newTextFontStyle acFontRegular) "acFontRegular") ((= newTextFontStyle acFontItalic) "acFontItalic") ((= newTextFontStyle acFontBold) "acFontBold") ((= newTextFontStyle acFontBoldItalic) "acFontBoldItalic") )) (alert (strcat "The new value for TextFontStyle is " newConstant)) ;; Reset TextFontStyle to its original value (vla-put-TextFontStyle (vla-get-Display preferences) currTextFontStyle) (alert (strcat "The TextFontStyle value is reset to " constant)) ) |
GMT+8, 2024-6-10 18:40
