指定新文本的字体大小。 支持的平台:仅窗口 属性值只读:不 类型:整数 新文本的字体大小。字体大小的限制由字体决定。 言论此属性的初始值为 10。 例子工 务 局: Sub Example_TextFontSize() ' This example returns the current setting of ' TextFontSize. It then changes the value, and finally ' it resets the value back to the original setting. Dim preferences As AcadPreferences Dim currTextFontSize As Integer Set preferences = ThisDrawing.Application.Preferences ' Retrieve the current TextFontSize value currTextFontSize = preferences.Display.TextFontSize MsgBox "The current value for TextFontSize is " & preferences.Display.TextFontSize, vbInformation, "TextFontSize Example" ' Change the value for TextFontSize preferences.Display.TextFontSize = 12 MsgBox "The new value for TextFontSize is " & preferences.Display.TextFontSize, vbInformation, "TextFontSize Example" ' Reset TextFontSize to its original value preferences.Display.TextFontSize = currTextFontSize MsgBox "The TextFontSize value is reset to " & preferences.Display.TextFontSize, vbInformation, "TextFontSize Example" End Sub Visual LISP: (vl-load-com) (defun c:Example_TextFontSize() ;; This example returns the current setting of ;; TextFontSize. It then changes the value, and finally ;; it resets the value back to the original setting. (setq acadObj (vlax-get-acad-object)) (setq preferences (vla-get-Preferences acadObj)) ;; Retrieve the current TextFontSize value (setq currTextFontSize (vla-get-TextFontSize (vla-get-Display preferences))) (alert (strcat "The current value for TextFontSize is " (itoa currTextFontSize))) ;; Change the value for TextFontSize (vla-put-TextFontSize (vla-get-Display preferences) 12) (alert (strcat "The new value for TextFontSize is " (itoa (vla-get-TextFontSize (vla-get-Display preferences))))) ;; Reset TextFontSize to its original value (vla-put-TextFontSize (vla-get-Display preferences) currTextFontSize) (alert (strcat "The TextFontSize value is reset to " (itoa (vla-get-TextFontSize (vla-get-Display preferences))))) ) |
GMT+8, 2024-6-10 17:39
