指定尺寸和公差对象的文本颜色。 支持的平台:仅窗口 属性值只读:不 类型:枚举acColor 使用介于 0 到 256 之间的颜色索引号,或此处列出的常量之一:
言论可以将颜色设置为数字索引值,范围从 0 到 256。为标准的七种颜色以及 BYBLOCK 和 BYLAYER 名称提供了常量。 如果使用,AutoCAD 将以默认颜色(白色或黑色,具体取决于您的配置)绘制新对象,直到它们被分组到块中。在图形中插入块时,块中的对象将继承颜色属性的当前设置。acByBlock 如果使用,新对象将采用绘制它们的图层的颜色。acByLayer 注意:此属性将覆盖给定尺寸或公差对象的 DIMCLRT 系统变量的值。
例子工 务 局: Sub Example_TextColor() ' This example creates an aligned dimension in model space and ' uses the TextColor property to toggle the dimension text color to red Dim dimObj As AcadDimAligned Dim point1(0 To 2) As Double, point2(0 To 2) As Double Dim location(0 To 2) As Double ' Define the dimension point1(0) = 5: point1(1) = 5: point1(2) = 0 point2(0) = 7: point2(1) = 5: point2(2) = 0 location(0) = 5: location(1) = 7: location(2) = 0 ' Create an aligned dimension object in model space Set dimObj = ThisDrawing.ModelSpace.AddDimAligned(point1, point2, location) ThisDrawing.Application.ZoomAll ' Read and display current dimension text color MsgBox "The dimension text color for this object is currently set to: " & dimObj.TextColor ' Change the dimension text color dimObj.TextColor = acRed ThisDrawing.Regen acAllViewports ' Read and display current dimension text color MsgBox "The dimension text color for this object is now set to: " & dimObj.TextColor & " (Red)" End Sub Visual LISP: (vl-load-com) (defun c:Example_TextColor() ;; This example creates an aligned dimension in model space and ;; uses the TextColor property to toggle the dimension text color to red (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) ;; Define the dimension (setq point1 (vlax-3d-point 5 5 0) point2 (vlax-3d-point 7 5 0) location (vlax-3d-point 5 7 0)) ;; Create an aligned dimension object in model space (setq modelSpace (vla-get-ModelSpace doc)) (setq dimObj (vla-AddDimAligned modelSpace point1 point2 location)) (vla-ZoomAll acadObj) ;; Read and display current dimension text color (alert (strcat "The dimension text color for this object is currently set to: " (itoa (vla-get-TextColor dimObj)))) ;; Change the dimension text color (vla-put-TextColor dimObj acRed) (vla-Regen doc acAllViewports) ;; Read and display current dimension text color (alert (strcat "The dimension text color for this object is now set to: " (itoa (vla-get-TextColor dimObj)) " (Red)")) ) |
GMT+8, 2024-6-2 17:28
