指定外部参照文件的位置。 支持的平台:仅窗口 属性值只读:不 类型:字符串 要搜索外部引用文件的目录的驱动器和路径。 言论如果选择在属性上按需加载,则此位置用于外部引用的副本。acEnableWithCopyXRefDemandLoad 例子工 务 局: Sub Example_TempXRefPath() ' This example returns the current setting of ' TempXRefPath. It then changes the value, and finally ' it resets the value back to the original setting. Dim preferences As AcadPreferences Dim currTempXRefPath As String Dim newTempXRefPath As String Set preferences = ThisDrawing.Application.preferences ' Retrieve the current TempXRefPath value currTempXRefPath = preferences.Files.TempXrefPath MsgBox "The current value for TempXRefPath is " & currTempXRefPath, vbInformation, "TempXRefPath Example" ' Change the value for TempXRefPath newTempXRefPath = "TestTempXRefPath" preferences.Files.TempXrefPath = newTempXRefPath MsgBox "The new value for TempXRefPath is " & newTempXRefPath, vbInformation, "TempXRefPath Example" ' Reset TempXRefPath to its original value preferences.Files.TempXrefPath = currTempXRefPath MsgBox "The TempXRefPath value is reset to " & currTempXRefPath, vbInformation, "TempXRefPath Example" End Sub Visual LISP: (vl-load-com) (defun c:Example_TempXRefPath() ;; This example returns the current setting of ;; TempXRefPath. It then changes the value, and finally ;; it resets the value back to the original setting. (setq acadObj (vlax-get-acad-object)) (setq preferences (vla-get-Preferences acadObj)) ;; Retrieve the current TempXRefPath value (setq currTempXRefPath (vla-get-TempXrefPath (vla-get-Files preferences))) (alert (strcat "The current value for TempXRefPath is " currTempXRefPath)) ;; Change the value for TempXRefPath (setq newTempXRefPath "TestTempXRefPath") (vla-put-TempXrefPath (vla-get-Files preferences) newTempXRefPath) (alert (strcat "The new value for TempXRefPath is " newTempXRefPath)) ;; Reset TempXRefPath to its original value (vla-put-TempXrefPath (vla-get-Files preferences) currTempXRefPath) (alert (strcat "The TempXRefPath value is reset to " currTempXRefPath)) ) |
GMT+8, 2024-6-2 18:57
