指定在尺寸值中禁止显示零英尺测量值。 支持的平台:仅窗口 属性值只读:不 类型:布尔
言论此属性的初始值为。False 注意:此属性将覆盖给定维度的 DIMZIN 系统变量的值。
例子工 务 局: Sub Example_SuppressZeroFeet() ' This example creates an aligned dimension in model space and ' uses SuppressZeroFeet to suppress or view the display of ' zero feet in the alternate dimension display Dim dimObj As AcadDimAligned Dim point1(0 To 2) As Double, point2(0 To 2) As Double Dim location(0 To 2) As Double ' Define the dimension point1(0) = 0: point1(1) = 5: point1(2) = 0 point2(0) = 5: point2(1) = 5: point2(2) = 0 location(0) = 5: location(1) = 7: location(2) = 0 ' Create an aligned dimension object in model space Set dimObj = ThisDrawing.ModelSpace.AddDimAligned(point1, point2, location) ' Set the dimension display to a style that works with SuppressZeroFeet dimObj.UnitsFormat = acDimLArchitectural ThisDrawing.Application.ZoomAll Toggle: Select Case MsgBox("Press OK to suppress or view the display of zero feet in the dimension", vbOKCancel) Case vbOK ' Toggle the display of zero feet for the dimension value dimObj.SuppressZeroFeet = Not (dimObj.SuppressZeroFeet) ThisDrawing.Regen acAllViewports Case vbCancel Exit Sub End Select GoTo Toggle End Sub Visual LISP: (vl-load-com) (defun c:Example_SuppressZeroFeet() ;; This example creates an aligned dimension in model space and ;; uses SuppressZeroFeet to suppress or view the display of ;; zero feet in the alternate dimension display (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) ;; Define the dimension (setq point1 (vlax-3d-point 0 5 0) point2 (vlax-3d-point 5 5 0) location (vlax-3d-point 5 7 0)) ;; Create an aligned dimension object in model space (setq modelSpace (vla-get-ModelSpace doc)) (setq dimObj (vla-AddDimAligned modelSpace point1 point2 location)) (vla-ZoomAll acadObj) ;; Set the dimension display to a style that works with SuppressZeroFeet (vla-put-UnitsFormat dimObj acDimLArchitectural) ;; Toggle the display of zero feet for the dimension value (vla-put-SuppressZeroFeet dimObj (if (= (vla-get-SuppressZeroFeet dimObj) :vlax-true) :vlax-false :vlax-true)) (vla-Regen doc acAllViewports) (alert "Suppression of zero feet toggled.") ;; Toggle the display of zero feet for the dimension value back to previous state (vla-put-SuppressZeroFeet dimObj (if (= (vla-get-SuppressZeroFeet dimObj) :vlax-true) :vlax-false :vlax-true)) (vla-Regen doc acAllViewports) (alert "Suppression of zero feet toggled back.") ) |
GMT+8, 2024-6-11 05:53
