指定椭圆的起始参数。 支持的平台:仅窗口 签名工 务 局: object.StartParameter
属性值只读:不 类型:双 有效范围为 0 到。2*PI 言论椭圆的开始和结束参数基于以下公式计算: P(Theta) = A * cos(Theta) + B * sin(Theta) 其中分别是半长轴和短轴。AB 例如,如果您的起始角度为 ,则根据上述公式计算相应的启动参数。同样,如果您的端角为 ,则根据上述公式计算相应的结束参数。Theta1P(Theta1)Theta2P(Theta2) 可以使用角度或参数来创建椭圆。 例子工 务 局: Sub Example_StartParameter() ' This example creates an ellipse and enters the start and ' end parameters to create an elliptical arc. Dim ellObj As AcadEllipse Dim majAxis(0 To 2) As Double Dim center(0 To 2) As Double Dim radRatio As Double ' Create an ellipse in model space center(0) = 5#: center(1) = 5#: center(2) = 0# majAxis(0) = 10: majAxis(1) = 20#: majAxis(2) = 0# radRatio = 0.3 Set ellObj = ThisDrawing.ModelSpace.AddEllipse(center, majAxis, radRatio) ' Enter a start parameter of 1.57, and an end parameter of 6.28 ellObj.StartParameter = 1.57 ellObj.EndParameter = 6.28 ZoomAll ' Find the start and end parameters for the ellipse MsgBox "The ellipse has a start parameter of " & ellObj.StartParameter & " and an end parameter of " & ellObj.EndParameter, vbInformation, "StartParameter Example" End Sub Visual LISP: (vl-load-com) (defun c:Example_StartParameter() ;; This example creates an ellipse and enters the start and ;; end parameters to create an elliptical arc. (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) ;; Create an ellipse in model space (setq center (vlax-3d-point 5 5 0) majAxis (vlax-3d-point 10 20 0) radRatio 0.3) (setq modelSpace (vla-get-ModelSpace doc)) (setq ellObj (vla-AddEllipse modelSpace center majAxis radRatio)) ;; Enter a start parameter of 1.57, and an end parameter of 6.28 (vla-put-StartParameter ellObj 1.57) (vla-put-EndParameter ellObj 6.28) (vla-ZoomAll acadObj) ;; Find the start and end parameters for the ellipse (alert (strcat "The ellipse has a start parameter of " (rtos (vla-get-StartParameter ellObj) 2) " and an end parameter of " (rtos (vla-get-EndParameter ellObj) 2))) ) |
GMT+8, 2024-6-10 15:30
