指定圆弧或椭圆的起始角度。 支持的平台:仅窗口 属性值只读:不 类型:双 以弧度为单位的起始角度。 言论例子工 务 局: Sub Example_StartAngle() ' This example creates an ellipse and enters the start and ' end angles to create an elliptical arc. Dim ellObj As AcadEllipse Dim majAxis(0 To 2) As Double Dim center(0 To 2) As Double Dim radRatio As Double ' Create an ellipse in model space center(0) = 5#: center(1) = 5#: center(2) = 0# majAxis(0) = 10: majAxis(1) = 20#: majAxis(2) = 0# radRatio = 0.3 Set ellObj = ThisDrawing.ModelSpace.AddEllipse(center, majAxis, radRatio) 'Enter a start angle of 45 degrees, and an end angle of 270 degrees ellObj.startAngle = 45 * (3.14 / 180) ellObj.endAngle = 270 * (3.14 / 180) ZoomAll MsgBox "The ellipse has a start angle of " & ellObj.startAngle * (180 / 3.14) & " and the end angle of " & ellObj.endAngle * (180 / 3.14) & " degrees.", vbInformation, "StartAngle Example" End Sub Visual LISP: (vl-load-com) (defun c:Example_StartAngle() ;; This example creates an ellipse and enters the start and ;; end angles to create an elliptical arc. (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) ;; Create an ellipse in model space (setq center (vlax-3d-point 5 5 0) majAxis (vlax-3d-point 10 20 0) radRatio 0.3) (setq modelSpace (vla-get-ModelSpace doc)) (setq ellObj (vla-AddEllipse modelSpace center majAxis radRatio)) ;; Enter a start angle of 45 degrees, and an end angle of 270 degrees (vla-put-StartAngle ellObj (* 45 (/ 3.14 180))) (vla-put-EndAngle ellObj (* 270 (/ 3.14 180))) (vla-ZoomAll acadObj) (alert (strcat "This ellipse has a start angle of " (rtos (* (vla-get-StartAngle ellObj) (/ 180 3.14)) 2) " and the end angle of " (rtos (* (vla-get-EndAngle ellObj) (/ 180 3.14)) 2) " degrees.")) ) |
GMT+8, 2024-6-10 16:29
