指定视区相对于当前 UCS 的捕捉旋转角度。 支持的平台:仅窗口 属性值只读:不 类型:双 以弧度为单位的角度。有效范围为 0 到 6.28。 言论不能更改活动图纸空间视口的捕捉基点。 在执行对任一 theor方法 的调用之前,对此属性的更改不会反映在图形中。UpdateRegen 注意:此属性的值存储在 SNAPANG 系统变量中。
例子工 务 局: Sub Example_SnapRotationAngle() ' This example changes the snap rotation angle for a ' model space and paper space viewport. ' Create a new model space viewport Dim viewportObj As AcadViewport Set viewportObj = ThisDrawing.Viewports.Add("NewViewport") ' Find the current snap rotation angle Dim currSnapAngle As Double currSnapAngle = viewportObj.SnapRotationAngle MsgBox "The current model space snap rotation angle is " & viewportObj.SnapRotationAngle, , "SnapRotationAngle Example" ' Change the snap rotation angle viewportObj.SnapRotationAngle = 1.5 MsgBox "The new model space snap rotation angle is " & viewportObj.SnapRotationAngle, , "SnapRotationAngle Example" ' Create a new paper space viewport Dim pviewportObj As AcadPViewport Dim center(0 To 2) As Double Dim width As Double Dim height As Double center(0) = 3: center(1) = 3: center(2) = 0 width = 40 height = 40 ThisDrawing.ActiveSpace = acPaperSpace Set pviewportObj = ThisDrawing.PaperSpace.AddPViewport(center, width, height) ' Find the current snap rotation angle currSnapAngle = pviewportObj.SnapRotationAngle MsgBox "The current paper space snap rotation angle is " & pviewportObj.SnapRotationAngle, , "SnapRotationAngle Example" ' Change the snap rotation angle pviewportObj.SnapRotationAngle = 1.5 MsgBox "The new paper space snap base point is " & pviewportObj.SnapRotationAngle, , "SnapRotationAngle Example" End Sub Visual LISP: (vl-load-com) (defun c:Example_SnapRotationAngle() ;; This example changes the snap rotation angle for a ;; model space and paper space viewport. (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) ;; Create a new model space viewport (setq viewportObj (vla-Add (vla-get-Viewports doc) "NewViewport")) ;; Find the current snap rotation angle (setq currSnapAngle (vla-get-SnapRotationAngle viewportObj)) (alert (strcat "The current model space snap rotation angle is " (rtos currSnapAngle 2))) ;; Change the snap rotation angle (vla-put-SnapRotationAngle viewportObj 1.5) (alert (strcat "The new model space snap rotation angle is " (rtos (vla-get-SnapRotationAngle viewportObj) 2))) ;; Create a new paper space viewport (setq center (vlax-3d-point 3 3 0) width 40 height 40) (vla-put-ActiveSpace doc acPaperSpace) (setq paperSpace (vla-get-PaperSpace doc)) (setq pviewportObj (vla-AddPViewport paperSpace center width height)) ;; Find the current snap rotation angle (setq currSnapAngle (vla-get-SnapRotationAngle pviewportObj)) (alert (strcat "The current paper space snap rotation angle is " (rtos currSnapAngle 2))) ;; Change the snap rotation angle (vla-put-SnapRotationAngle pviewportObj 1.5) (alert (strcat "The new paper space snap base point is " (rtos (vla-get-SnapRotationAngle pviewportObj) 2))) ) |
GMT+8, 2024-6-11 04:29
