重置具有“不再显示此警告”复选框的所有对话框,以便它们再次显示。 支持的平台:仅窗口 属性值只读:不 类型:布尔
言论此属性的初始值为。False 例子工 务 局: Sub Example_ShowWarningMessages() ' This example reads and modifies the preference value that ' resets all dialog boxes that have the ' "Don't Display This Warning Again" check box so they display again. ' ' When finished, this example resets the preference value back to ' its original value. Dim ACADPref As AcadPreferencesSystem Dim originalValue As Variant, newValue As Variant ' Get the system preferences object Set ACADPref = ThisDrawing.Application.Preferences.System ' Read and display the original value originalValue = ACADPref.ShowWarningMessages MsgBox "The ShowWarningMessages preference is set to: " & originalValue ' Modify the ShowWarningMessages preference by toggling the value ACADPref.ShowWarningMessages = Not (ACADPref.ShowWarningMessages) newValue = ACADPref.ShowWarningMessages MsgBox "The ShowWarningMessages preference has been set to: " & newValue ' Reset the preference back to its original value ' ' * Note: Comment out this last section to leave the change to ' this preference in effect ACADPref.ShowWarningMessages = originalValue MsgBox "The ShowWarningMessages preference was reset back to: " & originalValue End Sub Visual LISP: (vl-load-com) (defun c:Example_ShowWarningMessages() ;; This example reads and modifies the preference value that ;; resets all dialog boxes that have the ;; "Don't Display This Warning Again" check box so they display again. ;; ;; When finished, this example resets the preference value back to ;; its original value. (setq acadObj (vlax-get-acad-object)) (setq preferences (vla-get-Preferences acadObj)) ;; Read and display the original value (setq originalValue (vla-get-ShowWarningMessages (vla-get-System preferences))) (alert (strcat "The ShowWarningMessages preference is set to: " (if (= originalValue :vlax-true) "True" "False"))) ;; Modify the ShowWarningMessages preference by toggling the value (vla-put-ShowWarningMessages (vla-get-System preferences) (if (= originalValue :vlax-true) :vlax-false :vlax-true)) (alert (strcat "The ShowWarningMessages preference has been set to: " (if (= (vla-get-ShowWarningMessages (vla-get-System preferences)) :vlax-true) "True" "False"))) ;; Reset the preference back to its original value ;; ;; * Note: Comment out this last section to leave the change to ;; this preference in effect (vla-put-ShowWarningMessages (vla-get-System preferences) originalValue) (alert (strcat "The ShowWarningMessages preference was reset back to: " (if (= (vla-get-ShowWarningMessages (vla-get-System preferences)) :vlax-true) "True" "False"))) ) |
GMT+8, 2024-6-2 17:25
