在实时平移和缩放期间控制光栅图像的显示。 支持的平台:仅窗口 属性值只读:不 类型:布尔
言论此属性的初始值为。False 如果拖动显示已打开并启用,则当您重新定位原始图像时,图像的副本会随光标移动。ShowRasterImage 注意:此属性的此值存储在 RTDISPLAY 系统变量中。
例子工 务 局: Sub Example_ShowRasterImage() ' This example returns the current setting of ' ShowRasterImage. It then changes the value, and finally ' it resets the value back to the original setting. Dim preferences As AcadPreferences Dim currShowRasterImage As Boolean Set preferences = ThisDrawing.Application.Preferences ' Retrieve the current ShowRasterImage value currShowRasterImage = preferences.DISPLAY.ShowRasterImage MsgBox "The current value for ShowRasterImage is " & preferences.DISPLAY.ShowRasterImage, vbInformation, "ShowRasterImage Example" ' Change the value for ShowRasterImage preferences.DISPLAY.ShowRasterImage = Not (currShowRasterImage) MsgBox "The new value for ShowRasterImage is " & preferences.DISPLAY.ShowRasterImage, vbInformation, "ShowRasterImage Example" ' Reset ShowRasterImage to its original value preferences.DISPLAY.ShowRasterImage = currShowRasterImage MsgBox "The ShowRasterImage value is reset to " & preferences.DISPLAY.ShowRasterImage, vbInformation, "ShowRasterImage Example" End Sub Visual LISP: (vl-load-com) (defun c:Example_ShowRasterImage() ;; This example returns the current setting of ;; ShowRasterImage. It then changes the value, and finally ;; it resets the value back to the original setting. (setq acadObj (vlax-get-acad-object)) (setq preferences (vla-get-Preferences acadObj)) ;; Retrieve the current ShowRasterImage value (setq currShowRasterImage (vla-get-ShowRasterImage (vla-get-Display preferences))) (alert (strcat "The current value for ShowRasterImage is " (if (= currShowRasterImage :vlax-true) "True" "False"))) ;; Change the value for ShowRasterImage (vla-put-ShowRasterImage (vla-get-Display preferences) (if (= currShowRasterImage :vlax-true) :vlax-false :vlax-true)) (alert (strcat "The new value for ShowRasterImage is " (if (= (vla-get-ShowRasterImage (vla-get-Display preferences)) :vlax-true) "True" "False"))) ;; Reset ShowRasterImage to its original value (vla-put-ShowRasterImage (vla-get-Display preferences) currShowRasterImage) (alert (strcat "The ShowRasterImage value is reset to " (if (= (vla-get-ShowRasterImage (vla-get-Display preferences)) :vlax-true) "True" "False"))) ) |
( 苏ICP备2022047690号-1 )
GMT+8, 2024-6-10 21:32
