指定 AutoCAD 在打开包含自定义对象的图形时是否显示警告消息。 支持的平台:仅窗口 属性值只读:不 类型:布尔
言论此属性的初始值为。True 注意:此属性的值存储在代理通知系统变量中。
例子工 务 局: Sub Example_ShowProxyDialogBox() ' This example returns the current setting of ' ShowProxyDialogBox. It then changes the value, and finally ' it resets the value back to the original setting. Dim preferences As AcadPreferences Dim currShowProxyDialogBox As Boolean Set preferences = ThisDrawing.Application.Preferences ' Retrieve the current ShowProxyDialogBox value currShowProxyDialogBox = preferences.OpenSave.ShowProxyDialogBox MsgBox "The current value for ShowProxyDialogBox is " & preferences.OpenSave.ShowProxyDialogBox, vbInformation, "ShowProxyDialogBox Example" ' Change the value for ShowProxyDialogBox preferences.OpenSave.ShowProxyDialogBox = Not (currShowProxyDialogBox) MsgBox "The new value for ShowProxyDialogBox is " & preferences.OpenSave.ShowProxyDialogBox, vbInformation, "ShowProxyDialogBox Example" ' Reset ShowProxyDialogBox to its original value preferences.OpenSave.ShowProxyDialogBox = currShowProxyDialogBox MsgBox "The ShowProxyDialogBox value is reset to " & preferences.OpenSave.ShowProxyDialogBox, vbInformation, "ShowProxyDialogBox Example" End Sub Visual LISP: (vl-load-com) (defun c:Example_ShowProxyDialogBox() ;; This example returns the current setting of ;; ShowProxyDialogBox. It then changes the value, and finally ;; it resets the value back to the original setting. (setq acadObj (vlax-get-acad-object)) (setq preferences (vla-get-Preferences acadObj)) ;; Retrieve the current ShowProxyDialogBox value (setq currShowProxyDialogBox (vla-get-ShowProxyDialogBox (vla-get-OpenSave preferences))) (alert (strcat "The current value for ShowProxyDialogBox is " (if (= currShowProxyDialogBox :vlax-true) "True" "False"))) ;; Change the value for ShowProxyDialogBox (vla-put-ShowProxyDialogBox (vla-get-OpenSave preferences) (if (= currShowProxyDialogBox :vlax-true) :vlax-false :vlax-true)) (alert (strcat "The new value for ShowProxyDialogBox is " (if (= (vla-get-ShowProxyDialogBox (vla-get-OpenSave preferences)) :vlax-true) "True" "False"))) ;; Reset ShowProxyDialogBox to its original value (vla-put-ShowProxyDialogBox (vla-get-OpenSave preferences) currShowProxyDialogBox) (alert (strcat "The ShowProxyDialogBox value is reset to " (if (= (vla-get-ShowProxyDialogBox (vla-get-OpenSave preferences)) :vlax-true) "True" "False"))) ) |
( 苏ICP备2022047690号-1 )
GMT+8, 2024-6-10 21:40
