控制在绘图区域中单击鼠标右键是显示快捷菜单还是发出 Enter 键。 支持的平台:仅窗口 属性值只读:不 类型:布尔
言论此属性的初始值为。True 当此属性设置为 时,可以使用对象中的特性自定义在绘图区域中右键单击的功能。TruePreferencesUser 注意:此属性的值存储在快捷方式菜单系统变量中。
例子工 务 局: Sub Example_ShortCutMenuDisplay() ' This example reads and toggles the preference value which controls ' whether right-clicking in the drawing area displays a shortcut menu ' or issues ENTER. Dim ACADPref As AcadPreferencesUser Dim originalValue As Variant, newValue As Variant Dim newAction As String ' Get the drafting preferences object Set ACADPref = ThisDrawing.Application.Preferences.User ' Read and display the original value originalValue = ACADPref.ShortCutMenuDisplay newAction = IIf(originalValue, "displays the shortcut menu", "sends an ENTER keystroke to ACAD") MsgBox "Right-clicking the mouse CURRENTLY " & newAction, vbInformation ' Modify the AutoSnapMarker preference by toggling the value ACADPref.ShortCutMenuDisplay = Not (originalValue) newValue = ACADPref.ShortCutMenuDisplay newAction = IIf(newValue, "display the shortcut menu", "send an ENTER keystroke to ACAD") MsgBox "Right-clicking the mouse over the drawing WILL NOW " & newAction, vbInformation End Sub Visual LISP: (vl-load-com) (defun c:Example_ShortCutMenuDisplay() ;; This example reads and toggles the preference value which controls ;; whether right-clicking in the drawing area displays a shortcut menu ;; or issues ENTER. (setq acadObj (vlax-get-acad-object)) (setq preferences (vla-get-Preferences acadObj)) ;; Read and display the original value (setq originalValue (vla-get-ShortCutMenuDisplay (vla-get-User preferences))) (setq newAction (if (= originalValue :vlax-true) "displays the shortcut menu" "sends an ENTER keystroke to ACAD")) (alert (strcat "Right-clicking the mouse CURRENTLY " newAction)) ;; Modify the AutoSnapMarker preference by toggling the value (vla-put-ShortCutMenuDisplay (vla-get-User preferences) (if (= originalValue :vlax-true) :vlax-false :vlax-true)) (setq newValue (vla-get-ShortCutMenuDisplay (vla-get-User preferences))) (setq newAction (if (= newValue :vlax-true) "displays the shortcut menu" "sends an ENTER keystroke to ACAD")) (alert (strcat "Right-clicking the mouse over the drawing WILL NOW " newAction)) ) |
GMT+8, 2024-6-10 23:44
