通过设置显示快捷菜单的长按持续时间来控制时间敏感的右键单击行为。 支持的平台:仅窗口 属性值只读:不 类型:长 以毫秒为单位的数字,介于 100 和 10,000 之间。初始值为 250。 言论此属性会影响属性设置为 时的右键单击行为。SCMTimeModeTrue 注意:此属性的值存储在 SHORTCUTMENUDURATION 系统变量中。
例子工 务 局: Sub Example_SCMTimeValue() ' This example reads and modifies the SCMTimeValue property. ' Then the property is reset to its original value. Dim ACADPref As AcadPreferencesUser Dim originalValue As Integer, newValue As Integer ' Get the UserPreferences object and set the SCMTimeMode property to True Set ACADPref = ThisDrawing.Application.Preferences.User ACADPref.SCMTimeMode = True originalValue = ACADPref.SCMTimeValue MsgBox "The SCMTimeValue property is currently: " & originalValue newValue = 1000 ACADPref.SCMTimeValue = newValue MsgBox "The SCMTimeValue property has been set to: " & ACADPref.SCMTimeValue ' Reset the preference back to its original value ACADPref.SCMTimeValue = originalValue MsgBox "The SCMTimeValue property was reset back to: " & originalValue End Sub Visual LISP: (vl-load-com) (defun c:Example_SCMTimeValue() ;; This example reads and modifies the SCMTimeValue property. ;; Then the property is reset to its original value. (setq acadObj (vlax-get-acad-object)) (setq preferences (vla-get-Preferences acadObj)) ;; Get the UserPreferences object and set the SCMTimeMode property to True (vla-put-SCMTimeMode (vla-get-User preferences) :vlax-true) (setq originalValue (vla-get-SCMTimeValue (vla-get-User preferences))) (alert (strcat "The SCMTimeValue property is currently: " (itoa originalValue))) (setq newValue 1000) (vla-put-SCMTimeValue (vla-get-User preferences) newValue) (alert (strcat "The SCMTimeValue property has been set to: " (itoa (vla-get-SCMTimeValue (vla-get-User preferences))))) ;; Reset the preference back to its original value (vla-put-SCMTimeValue (vla-get-User preferences) originalValue) (alert (strcat "The SCMTimeValue property was reset back to: " (itoa originalValue))) ) |
GMT+8, 2024-6-10 18:07
